[SH...] Posted February 7, 2022 Share Posted February 7, 2022 How can I check this radius without curve.IMG_20220207_115726.jpg Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/ Share on other sites More sharing options...
[Ma...] Posted February 7, 2022 Share Posted February 7, 2022 I don't think it can be done without it. Unless you have 6.35 pin Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54018 Share on other sites More sharing options...
[Ke...] Posted February 7, 2022 Share Posted February 7, 2022 You may be lucky to find a non-standard size of probe diameter from your supplier, if you ask. Depending on the accuracy needed, you could make a DIY probe with a ball bearing. Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54020 Share on other sites More sharing options...
[Cl...] Posted February 7, 2022 Share Posted February 7, 2022 Maybe I'm way off here, but could you create a circle from tangent? The right side surface looks to be flat, so you could take a line/plane there copy and move it in the nominal 1/2 Ø (3.175) to center of those teeth. Then find the highest point on the opposite curved surface, copy the line/plane, rotate it 90° and move it to the that points location. Now you have you two lines/planes to construct the 6.35 circle? I don't remember if planes work in circle from tangent, but you get the idea. Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54022 Share on other sites More sharing options...
[Mi...] Posted February 7, 2022 Share Posted February 7, 2022 I think your best bet would definitely be to get a .250" gauge pin and clamp it in place on the part Without using a pin, there might be some way to make an alignment at the nominal center, then probe two space points at the nominal tangency points, then adjust the position of the alignment with a loop based on the result? But that seems really sketchy. Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54024 Share on other sites More sharing options...
[An...] Posted February 8, 2022 Share Posted February 8, 2022 when it comes to larger quantities, it would be worthwhile to have magnetic pins made with a Ø 6.35mm, provided the component is made of metal. Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54026 Share on other sites More sharing options...
[Er...] Posted February 8, 2022 Share Posted February 8, 2022 Using a few theoretical features may be possible. Measure a radius the pin would touch. Create a theoretical circle at the same center with a diameter=diameter+pin diameter. Do the same for the other radius. The intersection would be where the center of the pin would be. The distance from the hole to that intersection should be it. Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54028 Share on other sites More sharing options...
[Je...] Posted February 8, 2022 Share Posted February 8, 2022 . You don't have to. It's a basic dimension, and basic dimensions are not toleranced 😜 Oh come on... how many times have you wanted to tell this to an engineer. Here's your chance 🤣 Jeff Frodermann Meier Tool & Engineering Anoka, Minnesota . Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54030 Share on other sites More sharing options...
[Er...] Posted February 8, 2022 Share Posted February 8, 2022 Please sign in to view this quote. Not having the add-ons to measure properly makes things difficult. I'd just report the points deviation from nominal 🤣 Link to comment https://qualityforum.zeiss.com/topic/11068-contour-radius/#findComment-54032 Share on other sites More sharing options...
