[Aa...] Posted January 26, 2022 Share Posted January 26, 2022 We're using the setup in the attached pic to track the machine's stability over time. The issue I'm having is that, because the spatial axis (Y+) is 45 degrees off every coordinate plane, the planar rotation inherited from the machine alignment is unpredictable. (We've had it point the Z+ direction toward the granite.) Thoughts?PXL_20220126_190048470.jpg Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/ Share on other sites More sharing options...
[Ja...] Posted January 26, 2022 Share Posted January 26, 2022 You could take a point on the fixture and use it for rotation. Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54602 Share on other sites More sharing options...
[Aa...] Posted January 26, 2022 Author Share Posted January 26, 2022 Thanks, but I've tried adding points for planar rotation, and they've had no effect. In fact, I have to have the point that sets the Y origin above the axis of the reference. I've tried using that to set the Z+. I've also added a point on top of the cylinder. Still no joy. Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54604 Share on other sites More sharing options...
[Ma...] Posted January 27, 2022 Share Posted January 27, 2022 Make setup program where you will save alignment. Then in main program just load this stored alignment. You can load alignment as your base alignment, or you can load it as char. to use it for elements. Play with it 😃 Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54606 Share on other sites More sharing options...
[Er...] Posted January 27, 2022 Share Posted January 27, 2022 Take a plane on the fixed jaw of the vise? Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54608 Share on other sites More sharing options...
[Aa...] Posted January 27, 2022 Author Share Posted January 27, 2022 Please sign in to view this quote. This sounds like a very sneaky way to do it. So sneaky, in fact, that I'm not sure I understand it. Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54610 Share on other sites More sharing options...
[Ma...] Posted January 27, 2022 Share Posted January 27, 2022 🤣 OK 🤣 You will create new program where you set up your base alignment ( aka directions, zero point ... ) and manually or by CNC get touches. Then it is stored alignment. Then on main program you can create new alignment from features, or edit or load saved. Loading saved alignment will act like on autorun. Or you can load saved alignment as characteristic - it's somewhere in menu. You select your "setup" alignment, create theoretical feature ( aka. plane or point ) and set it as this loaded alignment. Then you can have some refference point from it. I think that some pictures should be better, but i am out of time. Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54612 Share on other sites More sharing options...
[Aa...] Posted January 28, 2022 Author Share Posted January 28, 2022 Please sign in to view this quote. I like this idea. This is going to be run monthly, so I can't be sure that the vice will be in the same place relative to the 8" reference. Would it work to have a plane in the start alignment? I loop the base alignment, so I don't want to have a measurement strategy that has to run each time it loops. If I put the plane in the start alignment, would that straighten out the orientation issues? Thanks for the input! Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54614 Share on other sites More sharing options...
[Er...] Posted January 28, 2022 Share Posted January 28, 2022 Please sign in to view this quote. This should work to constraint all six movements Cylinder from the 8" standard Point at the end of the standard Plane on the fixed jaw Link to comment https://qualityforum.zeiss.com/topic/11144-inheriting-z-direction-from-the-machine-alignment/#findComment-54616 Share on other sites More sharing options...
