SWAP MODELS
Some time (and revisions) ago it was discussed that this function was broken in some way. I don't know if it has been fixed since then.
A thing that never really worked are planes whose size differs greatly from the size in the feature. This is often the case with split planes of which you can only select a small portion (one patch) on the model, but later put points on a much bigger area. Then Calypso doesn't know which CAD patch to use for comparison and so ends up doing nothing.
https://qualityforum.zeiss.com/topic/11390-swap-models/#findComment-56152
