SWAP MODELS
If you have a program with a model, then bring in a newer Rev... Is there a way to associate the existing features to the new geometry ? The existing strategies are still present. I would think there is a select button similar to freeform surface surfaces used option
I'll have to revisit that. I've tried it before, and thought that was the purpose of that operation. Somehow it didn't work, in previous attempts..
The main thing is the selection of the features, and hitting apply. You will have to select them multiple times because it will only truly apply a handful at a time. They will show up in red once applied.
Some time (and revisions) ago it was discussed that this function was broken in some way. I don't know if it has been fixed since then.
A thing that never really worked are planes whose size differs greatly from the size in the feature. This is often the case with split planes of which you can only select a small portion (one patch) on the model, but later put points on a much bigger area. Then Calypso doesn't know which CAD patch to use for comparison and so ends up doing nothing.
