[Br...] Posted March 30, 2021 Share Posted March 30, 2021 Hello, I have set up a report to import the Nominal/Actual comparison view of our CT data. I would like to have the view to be on a full page by itself. Have tried creating a plot protocol page but unable to get the comparison view to show on it. Brian Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/ Share on other sites More sharing options...
[To...] Posted March 30, 2021 Share Posted March 30, 2021 Go to Characteristics Settings Editor. At top, select PiWeb Reporting and then select Display Plots in Report. Select the desired characteristic and Set to On. This should produce a full plot with plot protocol. Alternatively, in some characteristics with the green piweb button. If you click on this button, there will be a button with a red X or a green check mark. If you have a red x, click on it to make it a green check mark. This will toggle the On/Off setting described in the first paragraph. This option is not available on CAD Presentation Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56348 Share on other sites More sharing options...
[Br...] Posted March 30, 2021 Author Share Posted March 30, 2021 Hell Tom, Yes, it does produce a full plot in a separate window. I am trying to get it to show that way automatically in the PiWeb report. Thank you for the reply, Brian Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56350 Share on other sites More sharing options...
[To...] Posted March 30, 2021 Share Posted March 30, 2021 Did you use the Plot Protocol? If you need both types of report, you can add a second template to the PiWeb report in the multiple report window. It will create 2 reports but you won't be able to get a full size plot in the standard protocol without customizing your template. Are we any closer?Screenshot 2021-03-30 163253.jpg Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56352 Share on other sites More sharing options...
[Br...] Posted March 30, 2021 Author Share Posted March 30, 2021 Yes, we are getting closer! I am able to get the view I need by adding the second plot protocol template. It creates a full size view of all the plots though. I would like to customize the template to get just the one plot that I want into the first template. I've customized the template to show the plots as seen below. Have not yet been able to figure out how to get the Nominal/Actual plot to appear. I feel like I'm missing one little step somewhere. Thank you, Brian Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56354 Share on other sites More sharing options...
[To...] Posted March 31, 2021 Share Posted March 31, 2021 I think this because CAD Presentation is a different animal. Unfortunately, I have no clue for what to do next. Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56356 Share on other sites More sharing options...
[Br...] Posted March 31, 2021 Author Share Posted March 31, 2021 Okay. Thank you for the assistance! Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56358 Share on other sites More sharing options...
[fb...] Posted March 31, 2021 Share Posted March 31, 2021 Please sign in to view this quote. Is this a challenge? Because I can help you get a cool CAD deviation fully-interactive item on your report. 😜 Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56360 Share on other sites More sharing options...
[Br...] Posted March 31, 2021 Author Share Posted March 31, 2021 Hello Laura, Yes, this is what I am trying to do. Thank you, Brian Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56362 Share on other sites More sharing options...
[To...] Posted March 31, 2021 Share Posted March 31, 2021 Please sign in to view this quote. 93388EC4-7503-4D19-94E4-5A3772A9AF7F.jpeg Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56364 Share on other sites More sharing options...
[Jo...] Posted March 31, 2021 Share Posted March 31, 2021 Please sign in to view this quote. I've got a sister like that. If you want something done, tell her she can't. Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56366 Share on other sites More sharing options...
[Ri...] Posted March 31, 2021 Share Posted March 31, 2021 Please sign in to view this quote. The CAD Presentation will show up on the PlotProtocol as long as you have the display turned on inside of the CAD Presentation Characteristic. In addition, if you just want it to show up (or only certain characteristics form plots), you can mark them, and then for the PlotProtocol you can turn on hide. It will only show the characteristics that aren't marked. Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56368 Share on other sites More sharing options...
[Br...] Posted April 1, 2021 Author Share Posted April 1, 2021 Thank you Richard, I am able to get the image to show full page using the standard PlotProtocol report. But I am trying to get it into a customized report using the editor. Can't seem to find the right option. Brian Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56370 Share on other sites More sharing options...
[Ri...] Posted April 1, 2021 Share Posted April 1, 2021 Here you go. I hope this helps. Thanks. Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56372 Share on other sites More sharing options...
[Br...] Posted April 1, 2021 Author Share Posted April 1, 2021 Yes, that is what I needed. Thank you!! Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56374 Share on other sites More sharing options...
[Er...] Posted December 6, 2021 Share Posted December 6, 2021 I'm not sure why, but this doesn't seem to be working for me with the dynamic image. Does the work with Basic Piweb? I follow all the steps shown, but when i double click so the model updates, I get nothing. Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56376 Share on other sites More sharing options...
[Br...] Posted December 9, 2021 Author Share Posted December 9, 2021 Hello Eric, I've attached a pdf that shows the steps I use to get the Nominal/Actual Comparison view onto my PiWeb report. Hopefully that will help you out. Brian I noticed that two articles have been added the Knowledge Base that do a great job of explaining how to do this. PiWeb.JPGAdding Nom_Actual view to PiWeb report.pdf Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56378 Share on other sites More sharing options...
[Gu...] Posted December 13, 2021 Share Posted December 13, 2021 Another tip: In the "StandardProtocol.ptx" there is a hidden page called "Plot". If you deactivate "hidden", you also have all large plots in the "StandardProtocol.ptx". If the large plots are to be switched individually, then set all line templates to "Detailed" on the Plot page in the protocol element. Link to comment https://qualityforum.zeiss.com/topic/11420-nominalactual-comparison-view-into-piweb/#findComment-56380 Share on other sites More sharing options...
