[As...] Posted July 12, 2022 Share Posted July 12, 2022 I'm trying to get all related elements to a coordinate system. I found a previous thread showing how to use the creation_sequence_args function but that only seems to show what the coordinate system was dependent on whereas I would like to know what other elements are dependent on the coordinate system. For context I created some inspection elements and then used the cluster functionality to copy the inspection around my part resulting in lots of new elements named 'Copy 1, Copy 2,...'. I re-named all the coordinate systems associated with the clusters but now need to also rename every element associated to each coordinate system. Link to comment Share on other sites More sharing options...
[Se...] Posted July 13, 2022 Share Posted July 13, 2022 Hi Ashley! I've used the 'depends_directly_on_elements' token with fair to middling success in something similar to this. You'll note that the relationship is the inverse to what you are seeking so you'll have to do a little extra work to find what elements are dependent upon your coordinate system. As always, ymmv. Hope that helps! Link to comment Share on other sites More sharing options...
[As...] Posted July 19, 2022 Author Share Posted July 19, 2022 Sean, The 'depends_directly_on_elements' didn't tie back to the coordinate systems that were created but after renaming the nominals I could use that function to rename everything associated to them. Thanks for the help! Link to comment Share on other sites More sharing options...
