[Da...] Posted November 30, 2021 Share Posted November 30, 2021 Hello All, How do you apply MMC to radius ? Link to comment Share on other sites More sharing options...
[Ma...] Posted November 30, 2021 Share Posted November 30, 2021 If you enable MMC for circle it will automatically create "Diameter" evaluation - you just double this radius tolerance. But it can be pain in the a** with such small part of radius. I would rather see basic dimension on it with bigger position tolerance Link to comment Share on other sites More sharing options...
[SH...] Posted November 30, 2021 Share Posted November 30, 2021 This is not a feature of a size, how could the designer give a position tolerance!!.should be a profile tolerance... Link to comment Share on other sites More sharing options...
[Ro...] Posted November 30, 2021 Share Posted November 30, 2021 Double the Radius and double the tolerance. I will generally mask that characteristic so it doesn't show in the report, but calypso can still use it for MMC. If your Radius can be 51.5 to 51.7, then your diameter can be 103.0 to 103.4 Link to comment Share on other sites More sharing options...
[Er...] Posted November 30, 2021 Share Posted November 30, 2021 Go to Feature Representation and change it from Diameter to Radius. Link to comment Share on other sites More sharing options...
[To...] Posted December 1, 2021 Share Posted December 1, 2021 Seems like a perfect opportunity for using Profile. Link to comment Share on other sites More sharing options...
[Cl...] Posted December 1, 2021 Share Posted December 1, 2021 Please sign in to view this quote. YES! Link to comment Share on other sites More sharing options...
