Consecutive Data
Doesn't mean there is not a way to do with Calypso (?) but, to my knowledge, not automatically.
I've attached the Excel Merge macro.
This is an excel macro that will combine the results from all CALYPSO excel reports in a single folder. Customers like to see all their results in one file for one reason or another and this Excel macro is an easy way to do it.
The instructions are below.
1. Create a folder called "C:/tmp"
2. Put your files inside the folder "C:/tmp"
3. Open up the "Sort_Zeiss_Data_Macro_File.xls" found above (in same custom printout folder as this document is, its an excel doc)
4. Note: Make sure your macros are enabled inside Excel
5. Click on the "Combine Files" button
6. Enter in the file path of your result files, in this case "C:/tmp"
7. Your results are then displayed
Excel_Merge.xls
https://qualityforum.zeiss.com/topic/11516-consecutive-data/#findComment-57006
