[Vi...] Posted July 13, 2022 Share Posted July 13, 2022 Good morning, my name is Victor and I'm a Test Technician in the I+D dept. I'm using Gom Inspect Pro and Gom Volume Pro from 2 weeks ago aprox. I have some doubts in how to create one point from the intersection of two curves. I tried this: 1º I created a section in the CAD in witch the two curves are intersected. 2º I tried to construct a Curve and a Surface (Construct menu) and all the possible options of both sub-menus. I would like to see the distance in X - Axis between both points. (See attached images) I don't know how many ways are to continue/proceed. I'm stuck. I'll appreciate any type of explanation or comment trying to give me instructions or any idea. Thanks. 👍 Link to comment Share on other sites More sharing options...
[Be...] Posted July 14, 2022 Share Posted July 14, 2022 Hi, as far as I know you can't calculate an intersection point between curves, background: 3d curves will usually not intersect especially not on measured data. You can try to calculate the intersection between a curve and an element with a surface, e.g. a plane or for a 2d case you should be able to calculate the intersection between a line and a curve. But for your sketched application it could be much easier: Create two touch points with disc in the particular sketched area. You can use the touch point disc even on nominal curves and apply a referenced construction. Then you have an access to "corner points" and you can easily create a distance between these points. Hope this helps?! Regards, Bernd Link to comment Share on other sites More sharing options...
[Vi...] Posted July 14, 2022 Author Share Posted July 14, 2022 Tanks Bernd, I'll try to do it. Link to comment Share on other sites More sharing options...
