Zeiss CMM Calibration Version?
How do I find out which version of "Calibration Software" or the name of the "Calibration Software" Zeiss uses to calibrate a CMM?
I haven't found anything in the paper work from Zeiss on our last calibration.
Don't they just use a series of special measurement plans and a step gauge? At least that's what they usually do during maintenance. Or do you mean something else?
Rick Stanich, the PTB certificate for your year/version of calypso.
I've attached the 2021 version for example.
Once you've signed in, go to the downloads and select Calypso and it should show software you're able to download or already have and then if none available, if you don't have had an active SMA, to the right of the screen you'll see the versions you can click on to get the version of PTB you need,
What am I looking for in the portal?
[/quote]software
ZEISS CALYPSO 2021 PTB certificate EN.pdf
The only software that they use that is "special" is the Evaluation software where they build the trumpet charts (it also allows them to make/test corrections), but all the runs and evaluations are performed directly inside Calypso.
