Rotating points
I have measured a plane , which normal along X + axis. Then I copy paste that plane and change space axis to x minus for creating a new plane and I change the x-axis dimension according to my drawing requirement but the point in the X minus plane rotated by 90 degree as shown in the figure, is there is any way to to rotate the point the same as X + plane. I tried with the the start angle but it rotate the plane instead of points.
https://qualityforum.zeiss.com/topic/11642-rotating-points/
