[SH...] Posted November 10, 2021 Share Posted November 10, 2021 I have measured a plane , which normal along X + axis. Then I copy paste that plane and change space axis to x minus for creating a new plane and I change the x-axis dimension according to my drawing requirement but the point in the X minus plane rotated by 90 degree as shown in the figure, is there is any way to to rotate the point the same as X + plane. I tried with the the start angle but it rotate the plane instead of points.IMG20211110123348.jpgIMG20211110123359.jpg Link to comment https://qualityforum.zeiss.com/topic/11642-rotating-points/ Share on other sites More sharing options...
[Cl...] Posted November 10, 2021 Share Posted November 10, 2021 Why not use the circle path inside the plane feature(s) and change to single points? That way you can make them match. Link to comment https://qualityforum.zeiss.com/topic/11642-rotating-points/#findComment-57694 Share on other sites More sharing options...
[SH...] Posted November 10, 2021 Author Share Posted November 10, 2021 Please sign in to view this quote. I don't have cad model, anyway I will try it. It is electrical motor rotor housing I have gap between each points. Thank for your helps... Link to comment https://qualityforum.zeiss.com/topic/11642-rotating-points/#findComment-57696 Share on other sites More sharing options...
[Cl...] Posted November 10, 2021 Share Posted November 10, 2021 Please sign in to view this quote. You don't need a CAD model. Just open the strategy and click circle path on plane. You can set the start angle/Angle Range/Diameter. Link to comment https://qualityforum.zeiss.com/topic/11642-rotating-points/#findComment-57698 Share on other sites More sharing options...
[No...] Posted November 10, 2021 Share Posted November 10, 2021 The rotation of the points should depend on the direction of the X/Y axes of the plane's local coordinate system. So if you can make them match - by changing the second plane's rotation and also size/location if needed - the points should follow. Link to comment https://qualityforum.zeiss.com/topic/11642-rotating-points/#findComment-57700 Share on other sites More sharing options...
[Ja...] Posted November 10, 2021 Share Posted November 10, 2021 My part might be a little different than yours but the attachment describes what I do. Why doesn't Calypso have a mirror option is the real question.Presentation2.pdf Link to comment https://qualityforum.zeiss.com/topic/11642-rotating-points/#findComment-57702 Share on other sites More sharing options...
[SH...] Posted November 10, 2021 Author Share Posted November 10, 2021 Please sign in to view this quote. Thanks for the attachment.. Link to comment https://qualityforum.zeiss.com/topic/11642-rotating-points/#findComment-57704 Share on other sites More sharing options...
