Cad screen goes black
I'm having trouble with my cad view going black, and the only workaround ive found is to close calypso and restart it.
Seems like i've had this problem before, but i cant remember what the fix was.
Calypso 2021
7.2.0002 (02.07.2021)
16 Gig ram
Windows 10
No help, but it happened to me last week. Although we were having network connection problems
on that machine. So I don't know if that was the cause, just thought I'd mention it. Something to look at maybe?
Since upgrading to 7.2, I've had this happen to me a couple times. Its the worst kind of problem because it is random and low frequency. I can't find a root cause because I'm not able to replicate it. Minor problem but annoying.
Can any of you read an Error reporrt?
SYSTEM STATE
CALYPSO
Inspection: xxxxxx_REV_1
Creation software version: 7.2.0002
Date and time: #(1 November 2021 13:28:10)
Actual characteristic:
Actual feature:
Creation DME: ACCURA_2
Hostname: Quality-Laptop
Mancnc active: false
Navi mode: nil
Run mode: manuel
OS Windows 10 Enterprise win32 V6.2 nt i386 ucs2
CMM-OS
Actual configuration: E
Actual stylus: -Z
fwObject: Zeiss.CMMOS.OMControlBehaviourSimulation
ID chain CS:
IFCpresent: false
ncDisplayStatus:
SDO version: 6.6.5.4
Sensor: VAST_XTR
TCO pending: 0
PiWeb Reporting
PiWeb reporting version: 7.8.6.0
PDF Merger: Not installed
OBJECT
Zeiss.Calypso.Acis
classPool->Root.Smalltalk.Zeiss.Calypso.Acis superclass->Object format->16384 environment->Root.Smalltalk.Zeiss.Calypso name->Acis methodDict->MethodDictionary () subclasses->nil useCenterForManipulation->nil trace->nil counter->nil organization-> Startup->nil instanceVariables->nil stream->nil
METHODSTACK
Unhandled exception: Message not understood: #copyFrom:to:
UndefinedObject(Object)>>doesNotUnderstand:
Zeiss.Calypso.Acis class>>parsePosition:
Zeiss.Calypso.Acis class>>viewParams
Zeiss.Calypso.OMGeoAcis>>saveCompleteView:
Zeiss.Calypso.OMUITestplanEditor(Zeiss.Calypso.OMUIEditor)>>saveInspectionWithoutRevisionCompare
Zeiss.Calypso.OMUITestplanEditor(Zeiss.Calypso.OMUIEditor)>>menuSelectionSave
Zeiss.Calypso.OMUITestplanEditor>>menuSelectionSave
Zeiss.Calypso.OMUITestplanEditor(Zeiss.Calypso.OMUIEditor)>>performMenuSelection:
Zeiss.Calypso.OMWorkshop>>menuSelectionSave
[] in Zeiss.Calypso.OMWorkshop>>performMenuSelection:
BlockClosure>>ensure:
Cursor>>showWhile:
optimized [] in Zeiss.Calypso.OMUIInterface>>menuSelectionBlock:icon:
optimized [] in ActionButtonSpec>>typeConvert:
PluggableAdaptor>>setValue:
PluggableAdaptor(ValueModel)>>value:
CZToolbarButtonController>>trigger
TriggerButtonTracker(BasicButtonTracker)>>finishSelectionFor:
TriggerButtonTracker>>finishSelectionFor:
TriggerButtonTracker(SelectionTracker)>>redButtonReleasedEvent:
RedButtonReleasedEvent>>dispatchTo:
TriggerButtonTracker(SelectionTracker)>>handleEvent:
EventDispatcher>>dispatch:to:
EventDispatcher>>dispatchEvent:
RedButtonReleasedEvent(Event)>>dispatch
RedButtonReleasedEvent(Event)>>dispatchForWindowManager:
optimized [] in WindowManager>>safelyDispatchForWindowManager:
BlockClosure>>on:do:
WindowManager>>processNextEvent
optimized [] in [] in WindowManager>>newProcess
optimized [] in WindowManager>>newProcess
optimized [] in Process class>>forBlock:priority:
#endOfMessage#
So today im working on much smaller parts, and I've had very few problems.
I guess it could be larger cad models or maybe individual cad models causing problems.
I need to put a call into Zeiss tech for some other issues, maybe i can tack this on to that call.
I've mainly had this happen when point data is very high.
I read, some years back, maybe v6.x, that any scans over 20k points could cause errors in math and cause the ACIS kernel to hang up.
A black screen leads me to believe its the ACIS Kernel.
I had a similar issue with a different system. The issue there was that Windows is trying to use the onboard (Intel) chipset for the video, rather then the NVidia video card. Might be worth a check of your resolution settings to see if you have something similar going on.
