[Ke...] Posted October 22, 2021 Share Posted October 22, 2021 I have a feature that I need to measure that has 118 degrees of arc. I need an accurate diameter and R2 of the torus. If I start adding restrictions to X, Y, Z I can get R2 to read better but I am concerned it is a false positive since the Radii is critical. Is 118 deg enough to not restrict? I generally dont like less than 90 degrees. Link to comment https://qualityforum.zeiss.com/topic/11770-measuring-torus/ Share on other sites More sharing options...
[Cl...] Posted October 22, 2021 Share Posted October 22, 2021 Do as you are, and if your not already, take single points, not scans. Link to comment https://qualityforum.zeiss.com/topic/11770-measuring-torus/#findComment-58508 Share on other sites More sharing options...
[SH...] Posted October 22, 2021 Share Posted October 22, 2021 Please sign in to view this quote. Can I ask what is the problem in scanning?. Link to comment https://qualityforum.zeiss.com/topic/11770-measuring-torus/#findComment-58510 Share on other sites More sharing options...
[Cl...] Posted October 22, 2021 Share Posted October 22, 2021 I usually get a much better result that way. I would say it's more stable. Link to comment https://qualityforum.zeiss.com/topic/11770-measuring-torus/#findComment-58512 Share on other sites More sharing options...
[Ke...] Posted October 22, 2021 Author Share Posted October 22, 2021 I will try with single points and compare. I have had a few things I have changed to single points to make sure my vectors are the best possible to give better results. it can make a difference. Its not a huge difference but what I am looking at is critical. Link to comment https://qualityforum.zeiss.com/topic/11770-measuring-torus/#findComment-58514 Share on other sites More sharing options...
[Er...] Posted October 25, 2021 Share Posted October 25, 2021 When I am questioning a critical size on a small (less 90 degree) arc, I will evaluate it as a profile as well. I want to see what the surface is doing, compared to the model. Usually I am finding that it's machined correctly, and i am getting inaccurate size data. You can also restrain to the diameter nominal, and review where your X,Y,and Z measure. The truth will be somewhere between the two restrained measurements. Once you find the true center of the diameter, you will be able to report the accurate size. Link to comment https://qualityforum.zeiss.com/topic/11770-measuring-torus/#findComment-58516 Share on other sites More sharing options...
[Er...] Posted October 26, 2021 Share Posted October 26, 2021 I have gotten more accurate results by using a local alignment for the feature. Also makes it easier to troubleshoot. Link to comment https://qualityforum.zeiss.com/topic/11770-measuring-torus/#findComment-58518 Share on other sites More sharing options...
