Caliper Distance or different evaluation
I am trying to measure the distance between two theoretical lines built from intersecting planes. I am getting a result that makes sense to the problems my engineers are having, but I would like to isolate the distance at various points along the intersection. Is that possible? Attached is a screenshot of the part. These lines should be parallel to each other and to datum A which runs down the center axis of this cylinder.
A Caliper Distance in the X IS - 0.8591, SB - 0.8400.
Is this giving me the max deviation? I don't have the option to choose between max and minimum, it's just allowing center.
Would it be possible to evaluate this at different Y locations/points to show my engineers exactly where the deviation is in this part? Or would another evaluation method be more appropriate?
Thanks
Ben Brown
https://qualityforum.zeiss.com/topic/11930-caliper-distance-or-different-evaluation/
