[To...] Posted September 23, 2021 Share Posted September 23, 2021 I'm working on a part that has a cam shape around the OD. The cam is broken into different areas by angle and they are applying different Line and Surface Profile tolerances on each area. Sketch below does not depict actual areas. I added section lines to model to show the areas, as seen in the Curve and FFS pics. I created a single curve and then created new curves and re-called features points by point numbers, i.e. 1-48, 49-266, 267-367, etc., based on the segmented areas. If I use a 1 to 1 ratio of scanned points to curve points, this seems to work marginally ok. If I use a 3 to 1 ration, then I needed to change the point numbers by a factor of 3. However, when I view the actuals, the group of points seem to lose their clocking. They start slightly before the angled segment and end short of the next segment. I do 3 levels of curves scans and then re-call the curve points into a FFS for the Surface Profiles. The shift mentioned previously is more prominent. Any ideas on an alternate method?Screenshot 2021-09-23 100357.jpgcam curve.JPGcam ffs.JPG Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/ Share on other sites More sharing options...
[Cl...] Posted September 23, 2021 Share Posted September 23, 2021 Please sign in to view this quote. "I created a single curve and then created new curves and re-called features points by point numbers" Have you tried grabbing the points via the "Box" method? Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59492 Share on other sites More sharing options...
[Th...] Posted September 23, 2021 Share Posted September 23, 2021 Please sign in to view this quote. I think this is the way. Using point numbers as the boundary for recall is hilariously tricky. Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59494 Share on other sites More sharing options...
[Ma...] Posted September 23, 2021 Share Posted September 23, 2021 Selecting points by numbers is not good idea. If you scan one curve divided by segments, then you can recall just segment - but if you group segments into contiunously scan, then recalling first segment contains all points and other segments are empty. Box can be tricky too. Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59496 Share on other sites More sharing options...
[To...] Posted September 23, 2021 Author Share Posted September 23, 2021 Please sign in to view this quote. Trying that now. Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59498 Share on other sites More sharing options...
[Cl...] Posted September 28, 2021 Share Posted September 28, 2021 Tom, did you end up getting this to work? Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59500 Share on other sites More sharing options...
[To...] Posted September 28, 2021 Author Share Posted September 28, 2021 Please sign in to view this quote. Yes and I want to document the steps I had to take. It'll take a few screen grabs. Will post asap. Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59502 Share on other sites More sharing options...
[To...] Posted September 28, 2021 Author Share Posted September 28, 2021 Please sign in to view this quote. Yes and I want to document the steps I had to take. It'll take a few screen grabs. Will post asap. Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59504 Share on other sites More sharing options...
[To...] Posted September 29, 2021 Author Share Posted September 29, 2021 As promised, I've created a step-by-step of what I did to solve this issue.Culling Curve Points.pdf Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59506 Share on other sites More sharing options...
[Cl...] Posted September 29, 2021 Share Posted September 29, 2021 Thanks for that Tom. May come in handy one day. Link to comment https://qualityforum.zeiss.com/topic/11958-breaking-up-a-curve/#findComment-59508 Share on other sites More sharing options...
