PCM warning
In some newer Calypso versions there is a bug that erases the parameter window (I think it is Plan -> Advanced -> Parameter or something like this) on CNC start. Zeiss likes to define parameters in that window rather than in presettings of the program. Could this be the problem?
Open the original program and check before doing CNC start. If you have anything there copy everything to presettings of the program and it should run fine.
https://qualityforum.zeiss.com/topic/12036-pcm-warning/#findComment-59998
