[Ke...] Posted August 19, 2021 Share Posted August 19, 2021 I have loaded a new stylus system by hand but I keep getting the error message that the roller contacts are still open. I have attached a picture of the contacts of an old stylus system (left) compared to the new stylus sytem (right). I am assuming my issue is the contacts being different on the bottom of the stylus system, is this accurate? If so, is there anything I can do on my end to make this new stylus system work?pic.jpg Link to comment https://qualityforum.zeiss.com/topic/12210-roller-contacts-are-still-open/ Share on other sites More sharing options...
[Ja...] Posted August 19, 2021 Share Posted August 19, 2021 I dont think you can do anything about this. Make sure you buy the correct adapter plate. It looks like you have a XXT TL3 sensor and should make sure the description on website matches your sensor. Most likely you have bought an incorrect adapter plate. Link to comment https://qualityforum.zeiss.com/topic/12210-roller-contacts-are-still-open/#findComment-61110 Share on other sites More sharing options...
[Ke...] Posted August 19, 2021 Author Share Posted August 19, 2021 That is exactly what has happened. Operator error. However, what is the point in having these different style adaptor plates? Link to comment https://qualityforum.zeiss.com/topic/12210-roller-contacts-are-still-open/#findComment-61112 Share on other sites More sharing options...
[Ja...] Posted August 19, 2021 Share Posted August 19, 2021 It belongs to a different configuration of sensor head. maybe XXT TL2 or TL1. Link to comment https://qualityforum.zeiss.com/topic/12210-roller-contacts-are-still-open/#findComment-61114 Share on other sites More sharing options...
[To...] Posted August 20, 2021 Share Posted August 20, 2021 Jayesh is correct. You have adapter plates for XXT-TL1 and XXT-TL3. They are not interchangeable. To verify, check the label on the backside of the XXT sensor body. Link to comment https://qualityforum.zeiss.com/topic/12210-roller-contacts-are-still-open/#findComment-61116 Share on other sites More sharing options...
