Autorun drop down list
Is there any way to delete or rearrange programs from the drop down list?
Also when running a program and it crashed on a feature, is there an option to skip that feature and continue running or I have to fix that feature and rerun the program?
One method is to rename the Desk/Layer and put a number at the beginning. It is alphanumeric, so you can't use single digits beyond 9, or double digits beyond 99, etc.
I also added links to other Desk/Layers. On the other Layers, you can add a link back to Main Menu page.
You can mask all the characteristics that that feature is referenced to and your program will skip that feature.
If you are asking if you can run the rest of the program after it has stopped mid run due to collision then you will have to select all the remaining features and right click -> execute. Then after the run is done you will have to open all characteristics ( if any characteristics has "calculate now" press that too) and then view multiple or custom report however your reports are viewed.
Tom Oakes, I renamed the main menu and added an "0" in front of the name so it will always appears on top of the list. That works.
I upgraded from Calypso 2019 to 2021 recently but all of the programs are still in the 2019 folder. I tried to copy them into the 2021 folder but autorun isn't working correctly. The autorun still pulling programs from the 2019 folder. Any way to fix this?
You have to correct paths saved in program icons on autorun panels. Or move/rename main folder of 2019 and calypso autorun will ask you to correct paths
