[Th...] Posted August 13, 2021 Share Posted August 13, 2021 Is there any way to delete or rearrange programs from the drop down list? Also when running a program and it crashed on a feature, is there an option to skip that feature and continue running or I have to fix that feature and rerun the program?autorun lsit.png Link to comment https://qualityforum.zeiss.com/topic/12242-autorun-drop-down-list/ Share on other sites More sharing options...
[To...] Posted August 13, 2021 Share Posted August 13, 2021 Please sign in to view this quote. One method is to rename the Desk/Layer and put a number at the beginning. It is alphanumeric, so you can't use single digits beyond 9, or double digits beyond 99, etc. I also added links to other Desk/Layers. On the other Layers, you can add a link back to Main Menu page.autorun.jpgautorun2.jpg Link to comment https://qualityforum.zeiss.com/topic/12242-autorun-drop-down-list/#findComment-61264 Share on other sites More sharing options...
[Ja...] Posted August 13, 2021 Share Posted August 13, 2021 You can mask all the characteristics that that feature is referenced to and your program will skip that feature. If you are asking if you can run the rest of the program after it has stopped mid run due to collision then you will have to select all the remaining features and right click -> execute. Then after the run is done you will have to open all characteristics ( if any characteristics has "calculate now" press that too) and then view multiple or custom report however your reports are viewed. Link to comment https://qualityforum.zeiss.com/topic/12242-autorun-drop-down-list/#findComment-61266 Share on other sites More sharing options...
[Th...] Posted August 13, 2021 Author Share Posted August 13, 2021 Tom Oakes, I renamed the main menu and added an "0" in front of the name so it will always appears on top of the list. That works. I upgraded from Calypso 2019 to 2021 recently but all of the programs are still in the 2019 folder. I tried to copy them into the 2021 folder but autorun isn't working correctly. The autorun still pulling programs from the 2019 folder. Any way to fix this? Link to comment https://qualityforum.zeiss.com/topic/12242-autorun-drop-down-list/#findComment-61268 Share on other sites More sharing options...
[Ma...] Posted August 14, 2021 Share Posted August 14, 2021 You have to correct paths saved in program icons on autorun panels. Or move/rename main folder of 2019 and calypso autorun will ask you to correct paths Link to comment https://qualityforum.zeiss.com/topic/12242-autorun-drop-down-list/#findComment-61270 Share on other sites More sharing options...
[To...] Posted August 16, 2021 Share Posted August 16, 2021 Please sign in to view this quote. Did you uninstall 2019 before installing 2021? Link to comment https://qualityforum.zeiss.com/topic/12242-autorun-drop-down-list/#findComment-61272 Share on other sites More sharing options...
[Th...] Posted August 16, 2021 Author Share Posted August 16, 2021 I did not. I tried renaming the 2019 folder to 2021 and that still doesn't work properly. Link to comment https://qualityforum.zeiss.com/topic/12242-autorun-drop-down-list/#findComment-61274 Share on other sites More sharing options...
