[Ti...] Posted August 9, 2022 Share Posted August 9, 2022 I have little knowledge of Python, but I am learning. I need to do something simple, but when I test a program out in GOM's IDE workspace it just stalls out inside the program. For example....I wrote this quick program [quote] user_name = input('Enter User Name: ') print(user_name) wait = input('Press Enter to Continue') [/quote] What happens is when I right click and select > Run the program puts 'Enter User Name' in the bottom pane window, but the curser just circles and the program does not let me enter in my name? If I run the program in the command prompt it works. Any help is appreciated....thanks. Link to comment Share on other sites More sharing options...
[f2...] Posted August 10, 2022 Share Posted August 10, 2022 I dont know if GOM's interface will let you input responses like that. You can try using a dialog box that will prompt the user to input a value- # -*- coding: utf-8 -*- import gom def input_box(prompt=''): input=gom.script.sys.create_user_defined_dialog (content='<dialog>' \ '<title>*</title>' \ '<control id="Close"/>' \ '<position>center</position>' \ '<sizemode>fixed</sizemode>' \ '<size width="350" height="100"/>' \ '<content columns="1" rows="2">' \ '<widget rowspan="1" row="0" type="label" columnspan="1" column="0">' \ '<name>prompt</name>' \ '<tooltip></tooltip>' \ '<text></text>' \ '<word_wrap>false</word_wrap>' \ '</widget>' \ '<widget rowspan="1" row="1" type="input::string" columnspan="1" column="0">' \ '<name>input_text</name>' \ '<tooltip></tooltip>' \ '<value></value>' \ '<read_only>false</read_only>' \ '</widget>' \ '</content>' \ '</dialog>') input.prompt.text = prompt gom.script.sys.show_user_defined_dialog(dialog=input) return input.input_text.value user_name = input_box('Enter User Name:') print(user_name) Link to comment Share on other sites More sharing options...
