Graphic with Hard Zero with Result Element
Has anyone had luck trying to get the graphic (percentage of tolerance) to be correct for a Result Element with a hard zero?
In the Calibration Programs for the Stylus Systems I use Result Element to get the Ball Diameter and the Sigma (dev) for each stylus.
In the Custom Report if you unchecked the lower tolerance it calculated it correctly but it makes no difference in PiWeb so my Sigma Deviation of up to 0.010 always wants to make the nominal 0.005 not 0.000 which makes it look bad and if I add warning limits I am guessing it might turn yellow even though it is really good.
Any ideas on how to fix this? I even think the deviation number comes from the 0.005 not 0.000
  • 2 months later...
Thanks, that is nice to know. Wait for Zeiss to send me my new license files so I can play with 2021 on my offline seat.
  • 3 weeks later...
Going into to PiWeb reporting plus in settings and changing
to nominal seemed to help the deviation understand the hard zero but the graphic is still incorrect.
