MMC no bonus calculated
I measured a hole using a GDT principle maximum inscribed. I calculated the Datum system using GDT. But when I click MMR I don't get any bonus?  Any ideas?
I can post a link to the inspect file if need be.
Thanks.
  • 2 weeks later...
Hi John,
regarding your settings in the position tolerance dialog I can see that the dimension element is currently not selected.
If you select the corresponding element inside the dialog the bonus will appear in the label.
If you did not created the needed size element (can't see the contents of the explorer) either dialog (yellow warning sign) or the project guide will inform you that something is missing. The project guide can offer a possible solution to resolve the problem.
Best regards
Dinko
Edited
