[Li...] Posted May 24, 2021 Share Posted May 24, 2021 Hello all. Was hoping that someone could help me. I am needing to measure this long core pin 2 separate places but the pin is on a 2 deg. angle. Only when a do a cone or cylinder can I get the correct answer but I need 2 separate circles. TIA LisaPresentation1.pptx Link to comment https://qualityforum.zeiss.com/topic/12852-true-position-of-angled-core-pin/ Share on other sites More sharing options...
[Da...] Posted May 25, 2021 Share Posted May 25, 2021 What part are you having trouble with ? Are you having trouble probing ? Link to comment https://qualityforum.zeiss.com/topic/12852-true-position-of-angled-core-pin/#findComment-64824 Share on other sites More sharing options...
[Ma...] Posted May 25, 2021 Share Posted May 25, 2021 Have you tried intersecting the fueature using X1 at 9.04. Then TP than circle. Link to comment https://qualityforum.zeiss.com/topic/12852-true-position-of-angled-core-pin/#findComment-64826 Share on other sites More sharing options...
[To...] Posted May 25, 2021 Share Posted May 25, 2021 What characteristic(s) are you trying to report? Link to comment https://qualityforum.zeiss.com/topic/12852-true-position-of-angled-core-pin/#findComment-64828 Share on other sites More sharing options...
[Li...] Posted May 26, 2021 Author Share Posted May 26, 2021 I am trying to get the linear dimensions and the TP using a circle on the top of the core pin and a circle at the bottom. While doing a cylinder gets me the dimensions. work is wanting 2 circles one at top and one at bottom. Link to comment https://qualityforum.zeiss.com/topic/12852-true-position-of-angled-core-pin/#findComment-64830 Share on other sites More sharing options...
[Li...] Posted May 26, 2021 Author Share Posted May 26, 2021 Please sign in to view this quote. I am going to attempt to make that "0" then rotate the coordinate system 2Deg. Then measure the 2 circles. Link to comment https://qualityforum.zeiss.com/topic/12852-true-position-of-angled-core-pin/#findComment-64832 Share on other sites More sharing options...
[To...] Posted May 26, 2021 Share Posted May 26, 2021 If you create a secondary alignment, open it and then measure a cone feature, it will populate the Spatial and X/Y Origin properties needed to measure the 2 circles. Or, use the special button to translate and rotate to the desired postion. After you create the alignment, close it. Go to CAD, Pre-assignment for new features. Select the new alignment and leave the window open. Next, create your 2 circles. They will automatically have the new alignment applied to them. Link to comment https://qualityforum.zeiss.com/topic/12852-true-position-of-angled-core-pin/#findComment-64834 Share on other sites More sharing options...
