Plot settings
  • 3 months later...
We are having a similar issue. The Plot is reversed from the CAD view on the line profile of an involute. When we select Automatic (mirror), it also rotates the view. Is there a way to adjust the rotation of the Plot? We have had no training in PiWeb, so a custom report is out of our depth (maybe?)
https://qualityforum.zeiss.com/topic/12918-plot-settings/#findComment-65276
Create an alignment and use the special functions to align the plot the way you want it. This alignment can be used in the feature or in the Line Profile characteristic. If you are worried about the calculation differences between the DRF in the characteristic and the alignment, make sure that the evaluation settings for the features are the same in both.
https://qualityforum.zeiss.com/topic/12918-plot-settings/#findComment-65280
