[To...] Posted April 28, 2021 Share Posted April 28, 2021 Per the sketch below, I'm looking for confirmation as to the proper type of point to use for datum target C. In the attachment, I show the affects of using Touch, Space and Plane points in the Base Alignment. I'm leaning towards using a space point though I feel a plane point is the proper way. Anyway, I welcome your thoughts. Note: the sketch shows the datum point surface to be perpendicular to Datum B but in the attachments, you will see that there is a slight angle (~2.5°) . . Datum Target C screenshots.pdf Link to comment Share on other sites More sharing options...
[Ri...] Posted April 28, 2021 Share Posted April 28, 2021 I don't think you are going to see much of a difference using the Space Point vs the Plane Point. When doing 3-2-1, or 3d Best Fit Alignments, I just tend to use Plane Points as the software will ask you to use them (for the 3d Best Fit). Link to comment Share on other sites More sharing options...
[To...] Posted April 28, 2021 Author Share Posted April 28, 2021 Part 2 - There are several position call-outs of holes to A, B w/MMB and C. The MMB option is not available on the Symmetry Plane, even with View Tolerance (with MMC/LMC of the references) active. Any thoughts on a work-around to allow for datum shift Link to comment Share on other sites More sharing options...
[Ri...] Posted April 28, 2021 Share Posted April 28, 2021 Please sign in to view this quote. Hopefully this will be added in future releases, but it is currently not possible in Calypso. Link to comment Share on other sites More sharing options...
[Er...] Posted May 1, 2021 Share Posted May 1, 2021 I use the base alignment to find the part. Using datum targets is nice, but getting a solid lock onto the part is my priority. Using a calculated or constructed feature, like a symmetry plane, has led to grief in the middle of a capability run when Calypso pops up a "can't calculate alignment" due to part variability. 😮 In this case I'd make a base alignment that is made of features I already have to measure. Then I'd use an Alignment using -A- and -B- to find -C-. If I wanted to be sure -ABC- was locked in I could then make a conditional loop on an -ABC- alignment. Link to comment Share on other sites More sharing options...
