Probe parameters
When entering probe parameters for each stylus system such as A angle, B angle, radius, and shaft radius, are the units in my environment units? If I use inches should these radii be input as inches or as mm?
Also, does the shaft radius have an effect on the calculation of bending forces in the stylus? There is a tip that somebody had put a shaft radius of 0 when setting it up and a new tip is giving much different results.
https://qualityforum.zeiss.com/topic/13100-probe-parameters/
  • 1 month later...
