Plot an histogram
Good morning Angela,
I assume you have generated the histogram using a Package such as matplotlib or similar, i.e., we are not taking about a diagram which is native to GOM Inspect.
If this is the case, you can save the histogram to a image file and import this image with the "Create Image" command which you can access in the report workspace. See the attached screenshot to find the corresponding menu item.image.thumb.png.e82afb4a0fa985d147dd74513be730cd.png
Dear Micheal,
thank you for your kind answer. Yes I´m using plt.hist from matplotlib.
I will try the solution that you suggest but it looks like what I was looking for.
Thank you again.
KR Angela
