Usage of Custom Build Adaptors
Build a custom build adaptor for hole measurement (refer attached image), here white dot diameter is 8mm.  We change the setting in Acquisition parameters but still target points are not captured while scanning. Please guide to fix this issue.
  • 3 months later...
I am not sure if this is the case for your actual adapter but in the image you have provided the reference points appear to be retroreflective.
Typically when ordering adapters from a third party you will have the option to choose between contrast and retroreflective targets. The ATOS scanners cannot measure the location of retroreflective targets.
Additionally to use an adapter like this in the GOM Inspect software an adapter definition file would be needed. If you get adapters from GOM this is provided however for other adapters you will need to make your own adapter definition file. You can check the software documentation to see the process for this.
Hi,
from the picture they look like reflective reference points. These might be hard to scan with an ATOS (if you use one), so please try to set the reference points to "more points" in the acquisition parameters.
