probes release error
  • 2 months later...
Clean each of the probe plates with a lint-free rag or swab using at least 70% (I prefer 99%) Isopropanol alcohol.
Might clean the little balls/bars that locate the plates in the head with alcohol too, being extra carful to not leave anything behind (lint) and to not be aggressive while doing it.
Vacuum the probe bays accordion covers and clean the internals with alcohol. Might check to see if they're still tightly secured before redefining. Then redefine each holders location with the master probe.
Way out of balance or heavy probing systems might be an issue too.
Our RDS had similar issues. Removed the RDS plate from the head and the adapter plates from the probe sockets. A good cleaning with alcohol a couple of times cleared it up.
