how to program for composite position and multiple Single Segment Position
Hi everyone
I'm an mechanical engineer and this is my first time to ask question here, thanks everyone to answer my question.
Recently I'm struggling the program setup in Calypso, here is the case, it's most like a block with four holes, the datum A is the top surface, the datum B is center plan, the datum C is side surface, the four holes are the features to be measured with composite position, top line is the position control with respect to A,B and C, bottom line is the position control with respect to A
Understanding between our internal team are different for the top line setup
I attached the screenshots for setup, and also extend the callout if it multiple single segment, how I should setup program, please help me understand if my setup is correct, and please correct me if any wrong and explain
Appreciate for you all answers
how to program for composite position and multiple Single Segment Position.pdf
Because we're in metrology, I have to point out that you didn't click "calculate now" button on the single segment example. Sorry. 😃
