Adjusting the size of actual points
Hi all,
I just had my machine calibrated, and every year they do it, I run into the same problem. They make the arrow size for my actual points small, and every year I forget the way to fix it. How do I increase the size of the arrows? If a picture is needed, I can add one.
Somewhere in CAD settings is size. There can be even selected if it will be displayed as arrows or others.
Maybe right click on cad view to select "Display measured points" there can be settings too ( if element is in edit mode )
