[Do...] Posted February 8, 2021 Share Posted February 8, 2021 I have a true position callout on a bracket that only contains a basic angle. What is the best way to program this positional callout. Link to comment https://qualityforum.zeiss.com/topic/13568-true-position-of-a-cylinder-with-angle-callout/ Share on other sites More sharing options...
[SH...] Posted February 9, 2021 Share Posted February 9, 2021 Without understanding full drawing I can't tell accurately, the dimension 25.4 mm controls coordinate in one axis, angle control the orientation, I think one dimension missing control the height of the cylinder.. Link to comment https://qualityforum.zeiss.com/topic/13568-true-position-of-a-cylinder-with-angle-callout/#findComment-69548 Share on other sites More sharing options...
[Me...] Posted February 9, 2021 Share Posted February 9, 2021 There are a couple of ways to handle this... My preference is: Select the datums in your True Position characteristic (ABC), then your feature, there is a button called "Special" in the same window. Click that and you'll see location & angular offsets. Then as long as your datums represent the origin that is shown on the print, you offset to the locations shown on the print, in your case it is X & Z. Then do the rotation of your angle, you should see X & Z be ZERO in the original window. Link to comment https://qualityforum.zeiss.com/topic/13568-true-position-of-a-cylinder-with-angle-callout/#findComment-69550 Share on other sites More sharing options...
[Do...] Posted February 9, 2021 Author Share Posted February 9, 2021 Thanks for the response. Link to comment https://qualityforum.zeiss.com/topic/13568-true-position-of-a-cylinder-with-angle-callout/#findComment-69552 Share on other sites More sharing options...
