[To...] Posted February 1, 2021 Share Posted February 1, 2021 I know I can use ctrl-h to rename a range of features or characteristics but is there a way to "re-number the features? For example, if I create a group of space points and they are Point211 thru Point289, I might use ctrl-h to rename these features from "Point" to something "Detail B" but the numbers will still be 211 thru 289. Is there a trick to renumbering them to 1 thru 79? I understand I can create them in numerical order, rename them, then create the next batch and repeat. But what if they already exist? Link to comment https://qualityforum.zeiss.com/topic/13622-renaming-groups-of-features-characteristics/ Share on other sites More sharing options...
[Ri...] Posted February 1, 2021 Share Posted February 1, 2021 Maybe text editing the inspection or inspect file? Link to comment https://qualityforum.zeiss.com/topic/13622-renaming-groups-of-features-characteristics/#findComment-69834 Share on other sites More sharing options...
[Cl...] Posted February 1, 2021 Share Posted February 1, 2021 Please sign in to view this quote. I was not aware you could edit those. Link to comment https://qualityforum.zeiss.com/topic/13622-renaming-groups-of-features-characteristics/#findComment-69836 Share on other sites More sharing options...
[Ri...] Posted February 1, 2021 Share Posted February 1, 2021 They are just text files. While I don't recommend it, it can be done. There was a macro floating around here about changing stylus system names, it is the same principal. Link to comment https://qualityforum.zeiss.com/topic/13622-renaming-groups-of-features-characteristics/#findComment-69838 Share on other sites More sharing options...
