GD &T Question
I have two suppliers of the part attached . One uses a tri lobe chuck and datum B is distorted but while the part measures in print ..it will not function.
The other supplier uses pie jaw chucks measures in print and no issues. I ask engineering for a simple cylindricity call out on datum B. and was told it was not needed as the part is NOT to print ?
I have attached the section of the drawing and the response ..What is the correct methodology here ?
I'm getting hung up where you say that both supplied parts "measures in print", but engineering says "the part is NOT to print"
...seems like a riddle.
While the Envelope Principle controls the form in ASME by default, and is not *necessarily* a requirement to put it on the print, if the form of Datum B is found to be a root cause of fit/function, then it may be time for a print update.
Personally, if I am investigating a part issue, I have no problem putting in a cylindricity result as "REFERENCE ONLY", to highlight the suspect conditions (of course you may want to present it in a separate report)
His post talks about how they are held differently. Supplier A is holding the parts in a way that produces a tri-lobe effect. The part measures in specification (most likely with LSQ). Supplier B is holding the parts in a way that doesn't produce a tri-lob effect. The part measures in specification as well. Engineer is saying they do not measure in specification (most likely referring to a fit-function OTE).
This is kind of my reading between the lines interpretation.
A plug gage is always a great tool to have for cases like this.
Thanks Tom,
I ran a full print report with everything in specification. They complained that the part would not fit so I re checked and added the cylindricity report. 2080_1e514ee8cb2d21560a86feab376885cd.pdf
2080_9e5109e85ef9b6d2e2d3e4a81c507530.pdf
Yeah, my 20+ years in metrology has definitely found this to be true, but it all depends on the circumstances.
I have found more willingness to engage the customer on print revisions during product development, and initial PPAP, than *after* product launch. Whether the company one works at is on the supply side, or the end item customer, also makes a difference.
...I guess I'm an optimist 🤣
Depending on the customer, it can be a huge ordeal for a drawing change.
An example of a nightmare is in the automotive world where a lot of times you are Tier-3, and Tier-2 is the designer - it still has to be approved by Tier-1.
I took the initiative to be more active in the bidding process to try and catch things early on. It made life so much simpler down the road.
