Square Slot
You can take space point distances off the model which tells you how for you deviate from the surface. You then find your largest deviation and double it to determine your profile actual result if it's a bilateral profile. It get's more complicated if it is unilateral or has uneven distribution.
https://qualityforum.zeiss.com/topic/13958-square-slot/#findComment-72396
