Square Slot
Good afternoon, I have a questions : I want to measure this slot ( is a square slot) and i search in Calypso and i have only SLOT. I attached the photos. For this SLOT is necessary and the origine in he. Thak's in advance
If you have Curve, section it and scan a 2d line thru it.(repeat and several levels if you want to meet Profile of a surface)
Report Profiles
Thank's for info. I measure the Slot with points and is ok but the problems is the time (long time) . If is possible for remove the Clear Plane between points? I want to measere without Clear Plane . Thanks
Yes, it is possible use sub clearance plane and give clearance distance zero.
Can I ask how you calculate profile with points?.
You can take space point distances off the model which tells you how for you deviate from the surface. You then find your largest deviation and double it to determine your profile actual result if it's a bilateral profile. It get's more complicated if it is unilateral or has uneven distribution.
