[Jö...] Posted September 16, 2022 Share Posted September 16, 2022 Like the title. I have a Revopoint Mini 3D scanner connected to my computer and when I start GOM Correlate (latest downloadable version) it takes a couple of minutes and then GOM Correlate closes to desktop. If I unplug the Revo Mini, Correlate works fine. Is this something that can be fixed? Link to comment https://qualityforum.zeiss.com/topic/1397-gom-correlate-crashes-when-revopoint-mini-is-connected/ Share on other sites More sharing options...
[Iv...] Posted September 23, 2022 Share Posted September 23, 2022 Dear Jörgen, the Revopoint Mini 3D scanner is not a Carl Zeiss GOM Metrology product so any interfering is not a problem we can solve. Unfortunately there is nothing we can fix. Greetings Ivan Link to comment https://qualityforum.zeiss.com/topic/1397-gom-correlate-crashes-when-revopoint-mini-is-connected/#findComment-4656 Share on other sites More sharing options...
[Th...] Posted September 23, 2022 Share Posted September 23, 2022 Hi Jörgen, first of all: thanks for using Correlate. 🙂 What do you intend to do with it? Do you intend to use the Revopoint scanner with Correlate? This is not supported, but in the Free version we have the possibility to use USB3 cameras supporting the GeniCam standard... do you (try to) use this feature? Do you have other gom-drivers / Pro software installed? Anyways Correlate should not crash with another hardware connected. If you want to help us improving our products you can send us support data (Suite - Maintenance - Collect support data) to support@gom.com. Best regards, Thorsten Link to comment https://qualityforum.zeiss.com/topic/1397-gom-correlate-crashes-when-revopoint-mini-is-connected/#findComment-4658 Share on other sites More sharing options...
[Jö...] Posted September 29, 2022 Author Share Posted September 29, 2022 (edited) Hello and thanks for replying, The Revo mini contains a depth camera and an RGB camera and I was curious if Correlate would work with it, like a webcam/USB3 camera. Even if Correlate wouldn't work with it, I still expect Correlate to function correctly (and not crash) without me having to disconnect the scanner. I will try to get the files neccessary and send them to support. Thank you! Edited September 29, 2022 Link to comment https://qualityforum.zeiss.com/topic/1397-gom-correlate-crashes-when-revopoint-mini-is-connected/#findComment-4742 Share on other sites More sharing options...
[Jö...] Posted October 26, 2022 Author Share Posted October 26, 2022 So... mailed support with the files, but haven't heard anything back from them. Is a reply expected from support or how is the communication handled? Link to comment https://qualityforum.zeiss.com/topic/1397-gom-correlate-crashes-when-revopoint-mini-is-connected/#findComment-5032 Share on other sites More sharing options...
