[Fa...] Posted October 9, 2020 Share Posted October 9, 2020 Hello everyone, I'm trying to setup a pallet program in AutoRun. Is there a way to get rid of the following messages at the start of every part? Pretty much kills the whole pallet thing. No PCM available... Thanks in advance Fabio Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/ Share on other sites More sharing options...
[Da...] Posted October 9, 2020 Share Posted October 9, 2020 Hi Fabio, sorry I don't have an answer to you question, I'm only curios, do you really have 7,8 coefficient on all scales? Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75290 Share on other sites More sharing options...
[Fa...] Posted October 9, 2020 Author Share Posted October 9, 2020 Hi Dane, Default is set to 7,8. Screenshots were taken on our offline seat. I was trying to figure out a solution and see what switches back to default after the first part. Usually we don't change the defaults for scales. Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75292 Share on other sites More sharing options...
[Da...] Posted October 9, 2020 Share Posted October 9, 2020 And what machines do you have? Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75294 Share on other sites More sharing options...
[Ri...] Posted October 9, 2020 Share Posted October 9, 2020 Are you actually using Temperature Compensation? If you are, and you don't have built in probes, go into the Temperature Compensation menu, and delete where it shows which sensors it is reading from. If you aren't, then just turn it off. Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75296 Share on other sites More sharing options...
[Fa...] Posted October 12, 2020 Author Share Posted October 12, 2020 Please sign in to view this quote. Contura Please sign in to view this quote. I'm using TC, but don't have built in probes. Deleting the numbers for the sensors at least skips the first window. Thanks for that. Still have to hit "OK" for every part... Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75298 Share on other sites More sharing options...
[Da...] Posted October 12, 2020 Share Posted October 12, 2020 Hm, how about unchecking the Temperature Compensation checkbox? Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75300 Share on other sites More sharing options...
[Da...] Posted October 12, 2020 Share Posted October 12, 2020 Please sign in to view this quote. I'm also measuring on Contura and it has this sticker on it -> CTE X, Y, Z axis 0E-6/°C Just saying, maybe something to put more attention on. Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75302 Share on other sites More sharing options...
[Da...] Posted October 12, 2020 Share Posted October 12, 2020 As far as I know, you usually can't even change the coefficients of the scales. They are set up to the correct value according to the material of the scales. There are different scale materials in use, I think there are gold scales and glass ceramic scales. Not sure if they still use Invar scales. Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75304 Share on other sites More sharing options...
[Da...] Posted October 12, 2020 Share Posted October 12, 2020 Please sign in to view this quote. The setting can be found under Extras -> Settings -> CMM -> Temperature tab: Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75306 Share on other sites More sharing options...
[Da...] Posted October 12, 2020 Share Posted October 12, 2020 Ah, okay, was wrong about that. Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75308 Share on other sites More sharing options...
[Fa...] Posted October 13, 2020 Author Share Posted October 13, 2020 Please sign in to view this quote. Please sign in to view this quote. Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75310 Share on other sites More sharing options...
[Da...] Posted October 13, 2020 Share Posted October 13, 2020 Please sign in to view this quote. OK, OK, got that earlier, I was just curious, what do you use on "on-line" machine. Others: if I'm missing something or if there is anything to add to this, please don't hesitate. Link to comment https://qualityforum.zeiss.com/topic/14374-autorun-temperature-compensation/#findComment-75312 Share on other sites More sharing options...
