[Za...] Posted October 7, 2020 Share Posted October 7, 2020 Hello all, I'm trying to setup the characteristic to check the 0.51" distance from the angled bore projected to the surface to the straight bore's mid point and I'm having a heck of a time trying to get this to come in. What is the best way to project the angled bore to the surface? Right now it looks like it's projecting straight to the surface instead of angled towards the surface. Link to comment https://qualityforum.zeiss.com/topic/14424-projection-distance-issues/ Share on other sites More sharing options...
[Za...] Posted October 7, 2020 Author Share Posted October 7, 2020 To hopefully better explain the issue I'm having, here's a new picture: Link to comment https://qualityforum.zeiss.com/topic/14424-projection-distance-issues/#findComment-75602 Share on other sites More sharing options...
[Jo...] Posted October 7, 2020 Share Posted October 7, 2020 project both cylinders onto that plane, then measure 2d distance from the resulting circles(if using shell feature) points if using centerline. Link to comment https://qualityforum.zeiss.com/topic/14424-projection-distance-issues/#findComment-75604 Share on other sites More sharing options...
[Ro...] Posted October 7, 2020 Share Posted October 7, 2020 What John said. Intersect Cylinder + Plane and Cylinder + Plane and get 2 points and take simple Z distance from point to point. Link to comment https://qualityforum.zeiss.com/topic/14424-projection-distance-issues/#findComment-75606 Share on other sites More sharing options...
[Me...] Posted October 7, 2020 Share Posted October 7, 2020 I've never been fond of intersecting angled holes like the one you're trying to do. Particularly when having to make adjustments for machinists. If the angle has too much variance, it's not a good representation of what's going on with the location. We also have to report dimensions like this but when it comes to it, I report it at nominal every time. I look at it as the print is telling you to offset to that .051 and then rotate to the 13° to check the true position/depth, so when it comes to the .051 & 13° basics, I would only report the 13° from the cylinder I created and then put the .051 at nominal on a report. I'm interested in what everyone else does with these as well. Link to comment https://qualityforum.zeiss.com/topic/14424-projection-distance-issues/#findComment-75608 Share on other sites More sharing options...
[Jo...] Posted October 7, 2020 Share Posted October 7, 2020 Please sign in to view this quote. IDK what the datum structure is, or if you could get it to report the additional data for that TP . Either way, those are TARGETS not dimensions. I prefer not to report that on FAI submittals, but will report in house.. Link to comment https://qualityforum.zeiss.com/topic/14424-projection-distance-issues/#findComment-75610 Share on other sites More sharing options...
[Za...] Posted October 7, 2020 Author Share Posted October 7, 2020 Ahhh, my issue was I was trying to use circles to intersect with that top plane. Once I switched to a cylinder, everything came in like it should nominally in the distance dialogue box. Thank you everybody for your help! Link to comment https://qualityforum.zeiss.com/topic/14424-projection-distance-issues/#findComment-75612 Share on other sites More sharing options...
