Point list
Let’s talk about the report. On point 908, the actual Z measurement shows 2.0943 and the nominal Z shows 2.0921. I want to know where the software is getting the 2.0921 nominal from?
Martin Jansky. My engineer is asking the question. I have to explain to him because the call out on print is surface profile. I guess using cylinder 180° path(2 circles) is a bad method to use for profile. Right? Is there an easier way to measure the profile with easy results to read?
Scott, the X and Z values come from the points created from each of the circle paths in your cylinder relative to Datum C. If you scroll through the points, you'll see 2 sets of Y values. It appears you've collected approximately 600 points for each circle path, but I'm a bit miffed because I am seeing 3 circle paths on the screenshot. Any chance you revised the strategy since you collected the point data?
I think you will run into the same issue as far as what he is seeing. I don't turn on additional printout on a Profile because of having to explain to the people reading it what exactly they are looking at. I think the form plot for Curve and/or the CAD Presentation is just a much better way to show the error in a Profile.
With all respect, give him GD&T training, or fire him.
If he's checking your work, then he MUST know GD&T. If he make drawings -> he MUST know GD&T.
Othervise is useless to describe every measurements.
I would first start to displaying in CAD eval like cylinders - spheres are not much usefull. Play with cylinder radius and scale.
You could display it like curve or it could be viewed like cylindricality with locked radius, but i didn't tried it.
You can even draw simple drawing how is "profile" calculated.
Sorry, I am little upset. We have some people who don't fully understands even basics and they are my co-workes. They just apply what's in drawing regardless of part function / purpose.
