[Da...] Posted August 27, 2020 Share Posted August 27, 2020 Does anyone know if there is an alignment option in Calypso that allows me to perform a best fit alignment to one or more freeform surfaces? Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/ Share on other sites More sharing options...
[Er...] Posted August 27, 2020 Share Posted August 27, 2020 To one surface is possible. Just create a "work piece system". On several surfaces, as free form surfaces. No. One time i tried to get around this by creating a lot of curves and use "alignment from several curves". Worked pretty well, but did'nt feel satisfying... I guess you can use loads of points and 3d-best fit also. But an alignment of several free form surfaces is not an option. While this topic is up, any one who knows the of difference of ticking best-fit and ticking best-fit and gauss. What type of best-fit is just best-fit? Asked an AE once, mostly recived mumble as an answer... Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/#findComment-77908 Share on other sites More sharing options...
[Mi...] Posted August 27, 2020 Share Posted August 27, 2020 Please sign in to view this quote. If fitting to one surface is possible, can you just "recall feature points" on everything you want into one surface and fit to that? Never tried it myself. Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/#findComment-77910 Share on other sites More sharing options...
[Er...] Posted August 27, 2020 Share Posted August 27, 2020 Yes, you can make one free form surface of all surfaces. But then it's no longer per definition "one or more free form surfaces". Free form surfaces have always given me the most reasonable results when using them with their own respective strategy. Recalling points or curves many times works fine, but sometimes not. Problems tend more likely to occur for me on relativly larges surfaces. And always when you don't have time for it. 😃 I say reasonable results because I from time to time correlate the results with an optical 3d scanner from GOM. And they have always been closest to each other when I generate a strategy within the free form feature. (Furthest away is usually recalling points, even if there is plenty of them.) Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/#findComment-77912 Share on other sites More sharing options...
[Da...] Posted August 28, 2020 Author Share Posted August 28, 2020 The attached screenshot shows the two freeform surfaces I'd like to perform a best fit alignment on. So far I haven't been able to find a way to achieve this. None of the alignment options allow me to choose a freeform feature. What am I missing here?Capture.PNG Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/#findComment-77914 Share on other sites More sharing options...
[Ma...] Posted August 28, 2020 Share Posted August 28, 2020 Aren't they cylinders? You can create one surface from recalling those two and recalculate ( but don't forget to clear measured data - or do it from copies of those two ). But i dont know if it can be recalculated. Not at machine now Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/#findComment-77916 Share on other sites More sharing options...
[Ri...] Posted August 28, 2020 Share Posted August 28, 2020 Please sign in to view this quote. You need to create one Free-Form surface that references both surfaces. Then turn on Best-Fit inside of the Free-Form, and then click on the Alignment button. It will create a Free-Form alignment that can be used for characteristics/features. 1 Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/#findComment-77918 Share on other sites More sharing options...
[Da...] Posted August 28, 2020 Author Share Posted August 28, 2020 Martin, I wish they were cylinders as it would make my life a lot easier. It's hard to tell from the screenshot but it's more of a parabolic shape that follows an arc. Richard, you are a life saver! I didn't realize the alignment had to be created within the freeform feature settings. Thanks for all the great feedback, everyone!Capture2.PNG Link to comment https://qualityforum.zeiss.com/topic/14744-freeform-best-fit-alignment/#findComment-77920 Share on other sites More sharing options...
