[Ri...] Posted August 25, 2020 Share Posted August 25, 2020 Hello all, I am in a situation where I have done a substantial amount of programming on a part, and now a few features on the model were drawn incorrectly and subsequently machined incorrectly and programmed on the CMM incorrectly, so I need to be able to reload the new revision of the model and not lose the work I have completed on the rest of it, Is there and easy way to do that in Calypso 2019? I know in the CAM software I use for programming CNC's I can just upload the new model in a different "layer" and orient it so that it aligns with the original model. Any feedback/help is greatly appreciated! I have sent a service/applications request into Zeiss, but it seems like the users on this board are much quicker on the response back! Thanks in Advance!! Link to comment https://qualityforum.zeiss.com/topic/14786-re-loading-a-model-after-changes-are-made-to-it/ Share on other sites More sharing options...
[Jo...] Posted August 25, 2020 Share Posted August 25, 2020 Please sign in to view this quote. -Go into Cad>Modify Cad Entities>Hierarchy -Select your old model and delete it -Simply load your new model and orient it to the correct position -Save the model Now you can select those changed features again and program them from the correct model. The nominals that have been pulled from the correct parts of the old model will always stay in those features, even if you delete the model. Link to comment https://qualityforum.zeiss.com/topic/14786-re-loading-a-model-after-changes-are-made-to-it/#findComment-78318 Share on other sites More sharing options...
[Za...] Posted August 25, 2020 Share Posted August 25, 2020 I find it easier to leave the old model in there before deleting it to make sure i get it lined up correctly. Link to comment https://qualityforum.zeiss.com/topic/14786-re-loading-a-model-after-changes-are-made-to-it/#findComment-78320 Share on other sites More sharing options...
[Ri...] Posted August 25, 2020 Author Share Posted August 25, 2020 Thanks! I believe I did it correctly, once bringing in the new model, I just used the positioning tab in the modify cad model window, it appears to be as it should. I will find out shortly. Thanks again for the help! Link to comment https://qualityforum.zeiss.com/topic/14786-re-loading-a-model-after-changes-are-made-to-it/#findComment-78322 Share on other sites More sharing options...
