Part placement?
Good morning all,
A few months ago when I first started out on this CMM, I never setup a permanent fixture for some parts that I had to check. Now I have the same part to check but I do not remember the location that i had the part on the table. Is there a way to use the same program just in a different location than originally setup?
Thank you,
Lou
https://qualityforum.zeiss.com/topic/14848-part-placement/
What I have done which works pretty good is as follows.
Open program to get visual of part orientation. Make sure the interface is set up to reflect position is relative to base alignment.
Load the stylus used for the base alignment then under Plan>Travel to nominal position I will enter 0,0,0 then activate it using the
icon next to then coordinates that were entered. The CMM will now travel to the part location when program was last used.
I has worked well enough for me that I can run the program without doing doing a manual alignment.
Greg Kozera
https://qualityforum.zeiss.com/topic/14848-part-placement/#findComment-78932
Less time consuming then having someone guess where the part was and crash, doing a manual alignment should not be time consuming if your alignment is something slow then you should make a quick start alignment that is easy and quick to manually probe. I actually can't believe people are recommending trying to figure out how the part is supposed to be lined up on the table instead of running manual alignment. Unless i am completely misunderstanding what is being asked.
https://qualityforum.zeiss.com/topic/14848-part-placement/#findComment-78942
I agree with Martin Jánský about documenting with pictures and verbiage how to set up apart.
I will create a word document and save it. After that is done I would open program and go to Plan>Measurement info for CNC start>select. Pick the document you created and now it is embedded in program. It can be accessed as described above or under User Information in Start Measurement.
My previous post is for one of those times were you are told by the owner "Don't waste your time doing all that setup info. We will not see this part again". On More than one occasion we got a large order for parts two years after we were told we will not see it again. Since most of the components are small in size we will have more than one setup on the CMM table. By opening up the program and sending it to the original base alignment 0,0,0 we can see if we have to move fixtures or will be able to run it without any changes.
https://qualityforum.zeiss.com/topic/14848-part-placement/#findComment-78948
Thanks Amel P. I have tried doing the manual alignment but it didn't. I got pulled away while trying it again, so i will give it another shot. I am not worried about time. And I didn't think it took long at all to do the manual alignment. I am still a rookie and learning as much as possible. The E-stop and speed adjustment knob have been my best friends. Thank you
https://qualityforum.zeiss.com/topic/14848-part-placement/#findComment-78950
