Perp of cylinder
For a cylinder, I assume I can only do perpendicularity of the axis, but the drawing appears to be leaning towards the surface. Also, I can't fit the surface between 2 parallel planes, perpendicular to A (end face at bottom). Before I reach out to the customer, should I just assume the axis of the cylinder? Y14.5-1994
. perp of cylinder.pdf
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/
I see the problem now.. concerning data, could you scan "plane" using a circle path around the hole, then recall the data points into a nominal cylinder ? Maybe constrain it ? I don't see how you could establish a good vector with that size radius. Perpendicular could be 2 axis to another cylinder, correct ?
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/#findComment-79014
After thinking about this, I personally don't think perpendicularity can be legitimately applied to a surface of a cylinder however; I do believe I can measure lines on the surface, parallel to the cylinder's axis and validate whether they are all within spec or not. Any takers?
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/#findComment-79022
I think - all that matters here is axis on img on right side in direction left-right in view. So your lines does not cover this. I would try a circle ( less masked points ) or measure a few points from up to down to avoid hole and masking points on short line.
Even that Plane can be good point. But be carefull how you create that virtual plane.
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/#findComment-79028
Now I am at home - tommorow I'll can send pictures.
Basicly start with extracting a cylinder from model. Then make a circular scan path around a hole ( aka with same center as hole ).
Then you can create a plane with recall points and check recalculate nominals ( still no measured data ).
Plane is modified according to cylinder form. Change plane from teroetical to measurable a make same circular scan path.
This should be enough for measure parallelism and perpendicularity. If your CAD model view from Calypso is from Z- and X+ is left-right then perpendicularity for Y axis is not needed - only angle X/Z
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/#findComment-79036
I'm completely befuddled by this. I just don't see how this cylinder axis is perp to A. It is definitely parallel to A. I also don't see how the highlighted surface in an earlier snip is a cylinder. It looks like a plane to me. As I see this callout, the feature that is datum feature B must be perpendicular to the datum established by datum feature A within .002". I don't see where the cylinder comes into play at all.309_42925b68af8cdf783384349f7b0e2a4f.png
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/#findComment-79050
I see that now. Since the callout is applied to the surface and not associated with the dimension, it applies to the surface and not the axis. What is missing is the note EACH ELEMENT. This would mean that each linear element of that surface needs to be perp to the datum. If the axis was the desired control then a diameter symbol would have to be in the feature control frame. Either way, the callout is incorrect so we just have to take a guess or ask a question.
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/#findComment-79054
Tom, you can restrict radius for cylinder B and use cartesian perp. That will remove error from second axis.
I tried with a plane, but i didn't tested it. Two ways
- create a plane and set circular strategy around a hole
- create circular cut on cad model, make 2D curve ( possibly correct vectors ), measure, then recall points to plane ( but this can have a little second axis error )
https://qualityforum.zeiss.com/topic/14864-perp-of-cylinder/#findComment-79056
