Private Messaging is activated - check "How to" on how to disable it Γ—
Perp of cylinder
If i use a cylinder for the feature in a perpendicularity, why should worry about second axis?
If I use planes, they will have form error due to the curvature of the cylindrical surface that will be included in the perpendicularity result.
You could use the vector of the plane and calculate by formula.
But there is picture 6-3 in the ASME and it is possibly telling another story! πŸ˜•
Pic_6-3.pdf
Tom - with standard perp it's saying length from upper point of element to lower point of element ( axis on cylinder ) in combined axis ( both a1 and a2 ). In cartesian you choose only needed axis. 3001_21dd468fe62ac723e4c83d0fbe98f771.png
