Probe keeps unscrewing
Is the problem isolated to the same cube? or are you saying that all of your probes get loose in all of your cubes. To me, it seems unlikely that all of the probes and cubes would not hold torque. It is probably isolated to a specific cube.
I have probe systems that have maintained torque for years.
https://qualityforum.zeiss.com/topic/14882-probe-keeps-unscrewing/#findComment-79176
If you are using only your hands to tighten the cube or extension that is probably the reason. Either you get yourself some pin that fits in the hole or you buy two pairs of hook wrenches from Zeiss. I think they are great to use. about $15 a piece. Which is not that much money. They are more or less indestructible and will last you forever.
626109-0012-000 for Ø11
626109-0013-000 for Ø20
https://qualityforum.zeiss.com/topic/14882-probe-keeps-unscrewing/#findComment-79190
Would definitely use the wrench always, I have seen this happen when people try to hand tighten. If you can undo it by hand its most likely going to come loose in normal use. Ive never had an issue using the wrench, avoid tightening to hard with the wrench Ive had someone tighten it too hard and the extension actually became loose where it connects to the adapter plate that is not supposed to be able to turn.
https://qualityforum.zeiss.com/topic/14882-probe-keeps-unscrewing/#findComment-79196
  • 1 month later...
