[Da...] Posted August 12, 2020 Share Posted August 12, 2020 running 2019 sp3. In the past I would run a perpendicular line down the side of a bore, tweak it to zero, and ask for straightness. So far no problem. Then I would scallop pattern the line to 4 places around the bore . Mask the results then ask for a max Char. of the patterned line and get the max straightness to read out as 1 number. Now it displays all four readouts and the max Char. Tried it a couple ways it won't hide the multiple readouts. Any Ideas? Link to comment https://qualityforum.zeiss.com/topic/14884-mask-features-not-working-right/ Share on other sites More sharing options...
[SH...] Posted August 12, 2020 Share Posted August 12, 2020 Same problem I am facing I have a true position with MMC for a radius, so I used the circle for calculating the true position with MMC .I masked the diameter used for calculating the true position but it pops out in my pi web report. I create a mini plan excluding the diameter but still it would not work. I think if calypso use a characteristic for calculating something else, it will pop out in report that doesn't matter is masked or not.. Link to comment https://qualityforum.zeiss.com/topic/14884-mask-features-not-working-right/#findComment-79206 Share on other sites More sharing options...
[Is...] Posted August 12, 2020 Share Posted August 12, 2020 for the Piweb reporting: viewtopic.php?f=14&t=446 Link to comment https://qualityforum.zeiss.com/topic/14884-mask-features-not-working-right/#findComment-79208 Share on other sites More sharing options...
[Ma...] Posted August 12, 2020 Share Posted August 12, 2020 If using PiWeb you can Mark the characteristics and hide them. In the Definition of Multiple Reports click Mark Characteristics and turn on the ones you don't want to see. Then make sure to check Hide.Mark Characteristics.JPG Link to comment https://qualityforum.zeiss.com/topic/14884-mask-features-not-working-right/#findComment-79210 Share on other sites More sharing options...
[Ri...] Posted August 12, 2020 Share Posted August 12, 2020 Ditto to what is said above. I've asked if they can add the Mark option to the right click menu context as it would make it a lot easier to Mark characteristics instead of the current way. Link to comment https://qualityforum.zeiss.com/topic/14884-mask-features-not-working-right/#findComment-79212 Share on other sites More sharing options...
[Da...] Posted August 14, 2020 Author Share Posted August 14, 2020 I tried a few of the suggestions here , but marking was grayed out and I couldn't find the other pages location... Link to comment https://qualityforum.zeiss.com/topic/14884-mask-features-not-working-right/#findComment-79214 Share on other sites More sharing options...
