[Me...] Posted May 21, 2018 Share Posted May 21, 2018 Just a quick question, with probably an easy answer.. So I have a large 24" surface, and when I go to extract a part of the plane I want to use as my spatial, I got the separation you see in the picture. It has extracted Plane 1 (highlighted purple), and the 4 blue colored and numbered planes are separate from Plane 1, even though they are one continuous piece on both the model (Z nominals), and machined part. Is there an easy way to fuse these planes together, so I can speed up my alignment, using a large span of the part as opposed to recalling all the individual planes as 1 plane? Or can I just place the points in space where I need them anyways? Thanks.Connected Plane.jpg Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/ Share on other sites More sharing options...
[Cl...] Posted May 21, 2018 Share Posted May 21, 2018 I have seen this before. You can highlight one plane, open it up (strategy) and enter points/polyline on the other 4 surfaces, turning it into one plane. Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79266 Share on other sites More sharing options...
[Me...] Posted May 21, 2018 Author Share Posted May 21, 2018 Thanks Clarke, kinda figured, that's all I was wondering, wasn't sure if it would mess with the calculating/evaluation. Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79268 Share on other sites More sharing options...
[No...] Posted May 22, 2018 Share Posted May 22, 2018 Try the following menu item: CAD > Modification > Merge faces with same geometry This should create one surface out of connected faces that are of the same type and orientation. Caution: this will modify faces on the whole model! It's mainly used to merge halved cylinders of bores, but should also work here. Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79270 Share on other sites More sharing options...
[Ja...] Posted May 30, 2018 Share Posted May 30, 2018 Try this, CAD> CAD File> Automatic Healing check the "Simplification", "Stitching", and "Correct boundary curves" boxes then click "OK" then pick your surface again. Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79272 Share on other sites More sharing options...
[Ke...] Posted June 5, 2018 Share Posted June 5, 2018 Cad > Create Feature > highlight all the surfaces> to the right of geometry click plane > click the button to the left of geometry Result: one plane feature Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79274 Share on other sites More sharing options...
[Br...] Posted August 7, 2020 Share Posted August 7, 2020 Sounds easy. Obviously I am missing something. Selected the 2 surfaces that make up the plane. Clicked 'Plane" - All good so far. Clicked the geometry button - only 1 section was still highlighted. Opened up the created plane - it is only using 1 section. Any suggestions?Plane Construction.jpg Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79276 Share on other sites More sharing options...
[Ch...] Posted August 7, 2020 Share Posted August 7, 2020 You could make 4 separate planes, then recall feature points into a single plane. Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79278 Share on other sites More sharing options...
[Da...] Posted August 14, 2020 Share Posted August 14, 2020 Brian, what Kevin says works. Graphically isn't highlighted right, but if you check X,Y,Z of created planes you will see it works. Just keep in mind that the selection sequence matters. edit: it won't calculate lenghts right though. At least not on 6.4.28 version. Link to comment https://qualityforum.zeiss.com/topic/14894-weldingjoining-plane-faces/#findComment-79280 Share on other sites More sharing options...
