Max Dev.
Ok.I have a cylinder that has 6 IDS pinched through it at 30 Deg Apart. I need to measure all 6 Ids and report out the max difference in Z to each OTHER. Mind is drawing a blank on who to accomplish this. I got the circles measured with info but I just cant figure out how to tell ol calypso to give me the max difference in Z. I have played around with Max feature and result element but im coming up empty..
Thoughts
Use Maximum Feature / Z Value and Min Feature / Z value. Then either a result element to report the difference or a distance between each one.
Just re-read your post and saw that you were having trouble with this. I'll be back...
